Home › Forums › Products › Stompboxes › New MIDI issues with Timefactor › Reply To: New MIDI issues with Timefactor
April 25, 2021 at 8:12 pm
#157700
joecozzi wrote:
Are you sure the TimeFactor is set to receive on the same channel the Smartclock is set to? Are you using 5-pin DIN cables or are using another combination?
Yes I’m using a 5 pin DIN directly connected to the output of the smartgen clock. Connecting the same cable to other pedals works.
As for settings, I’ve tried these combos, saving/restarting as applicable after every change. Nothing makes a difference – the Timefactor isn’t seeing any MIDI input.
(the first pair of settings is what used to work)
1. Smartclock P CH setting (MIDI out channel): OFF
Timefactor RCV CH setting: OMNI
2. Smartclock P CH: 1
Timefactor RCV CH: 1
3. Smartclock P CH: 1
Timefactor RCV CH: OMNI
