Home › Forums › Products › Stompboxes › Problem With Micro Pitch and Midi › Reply To: Problem With Micro Pitch and Midi
May 3, 2021 at 4:31 am
#157747
Thanks for the reply. Yes, I believe I have the Micro Pitch set to Midi 2, A bit confusing in the manual but I’ll double check. And yes I’m using a 5-pin DIN to MIdi cable. I’ll try the CC changes for bypass and active, that might be just fine for me. Saving the presets so they can be recalled in a bypass state, Is that somewhat easy and explained in the manual as well? Thanks again.
