Home Forums Products Stompboxes Problem With Micro Pitch and Midi Reply To: Problem With Micro Pitch and Midi
#157748
joecozzi
    dirtybuck wrote:
    Saving the presets so they can be recalled in a bypass state, Is that somewhat easy and explained in the manual as well?
    All you have to do is go to the preset you want, bypass it and press & hold the Tap LED button. Then press the active LED button to save. Now, anytime you recall that preset it will come up in bypass.
