Home Forums Products Stompboxes Overall Killdry function on the H9 for use in a Parallel Effect chain Reply To: Overall Killdry function on the H9 for use in a Parallel Effect chain
#157750
joecozzi
    docnormal wrote:
    Does the Kill Dry Mode works on all Effects ?
    Yes
    docnormal wrote:
    How is this on Modulation and Pitcheffects ? Do I have the dry Signal on top in my parallel Effect Chain ?
    When [KILDRY] is enabled (YES), the dry signal is removed from the output and the H9 only outputs a 100% wet level. For some of the Presets the Intensity control acts as a Wet/Dry Mix control. For these Presets, if [KILDRY] is YES, the Intensity control is disabled.
