Overall Killdry function on the H9 for use in a Parallel Effect chain
Home Forums Products Stompboxes Overall Killdry function on the H9 for use in a Parallel Effect chain
    • #116469
      docnormal
        I’m using the H9 in one of the 3 channels of  the Parallelizer from Musicom Lab.
        In order not to sum up the dry signal in the dry and effect chain, I put the H9 in the Kill Dry Mode for all.
        Does the Kill Dry Mode works on all Effects ? On the Delay and the Reverb Effects I can choose the Wet/Dry Mix and give them 100% Wet.
        How is this on Modulation and Pitcheffects ? Do I have the dry Signal on top in my parallel Effect Chain ?
      • #157750
        joecozzi
          Yes
          When [KILDRY] is enabled (YES), the dry signal is removed from the output and the H9 only outputs a 100% wet level. For some of the Presets the Intensity control acts as a Wet/Dry Mix control. For these Presets, if [KILDRY] is YES, the Intensity control is disabled.
