Home › Forums › Products › Stompboxes › Setting a parameter with MIDI at program change › Reply To: Setting a parameter with MIDI at program change
        May 7, 2021 at 2:02 pm
        #157794
I’m not quite sure that’s the problem. I works on some of the Presets but on others, where the parameter is it just says – EXPRESSION PEDAL MAPPINGS ARE DISSABLED WHEN THE PRESET READS DIRECTLY FROM THE EXPRESSION PEDAL..
