Home Forums Products Rackmount H8000FW Address Error – Help Needed Reply To: H8000FW Address Error – Help Needed
#157852
    I'm afraid that this is a "catch-all" error that can have many causes. It is most likely to be some kind of hardware problem.
    If it happens often, at different times, showing different numbers you should contact support@eventide.com
    If it happens only when doing one particular thing and showing the same numbers, you should give us more information.
    If it happens at startup, you should remove any cards from the slot and re-initialize (see UM).
