Home Forums Products Stompboxes H9 MIDI BYPASS WITH GIGRIG G3–IMPOSSIBLE??? Reply To: H9 MIDI BYPASS WITH GIGRIG G3–IMPOSSIBLE???
#157903
joecozzi
    There is no CC defeat. Are you sure you’re sending to the correct MIDI a channel? I just tried it on mine and it works with any value greater than 64. I also programmed the MIDI controller to send a program change as well as a CC to bypass and it works.
    What are the exact actions you’ve programmed on your G3 button?
