Home Forums Products Stompboxes H9 MIDI BYPASS WITH GIGRIG G3–IMPOSSIBLE??? Reply To: H9 MIDI BYPASS WITH GIGRIG G3–IMPOSSIBLE???
#157913
NOW THAT’S THE TRICK.
It works now. I can designate the CC channel of my choice, and a value of 67 executes the Bypass. PROBLEM SOLVED.
OK, HERE’S THE REAL PROBLEM. Your H9 User Manual makes no mention of what values do what with various CC messages. Please make and implement a factory CC control map. If it has to be programmed one way or another, make a plan that works and your app will allow me to change it if I want. OR, just publish the values that execute commands. It’s nowhere in your user documentation, you had to tell me on this forum. WHICH I APPRECIATE TREMENDOUSLY. Just might save others some hair.
Thanks for your help, it is much appreciated!
