Home Forums Products Stompboxes Latency/lag with presets Reply To: Latency/lag with presets
#157947
joecozzi
    Have you checked to make sure that the presets that are giving you this problem aren’t programmed to be in an alternate routing other than “Normal?”
    My advice would be to back up your presets and System Settings and conduct a factory reset. If that doesn’t work, reinstall the firmware and reset it again.
