Home › Forums › Products › Stompboxes › Latency/lag with presets › Reply To: Latency/lag with presets
May 28, 2021 at 2:07 am
#157961
joecozzi wrote:
Have you checked to make sure that the presets that are giving you this problem aren’t programmed to be in an alternate routing other than “Normal?”
My advice would be to back up your presets and System Settings and conduct a factory reset. If that doesn’t work, reinstall the firmware and reset it again.
This worked!! Thank you
