Home › Forums › Products › Stompboxes › Micro Pitch Device Mgr. Issue › Reply To: Micro Pitch Device Mgr. Issue
May 31, 2021 at 2:51 am
#157988
Let’s try this:
1-Turn the pedal off by disconnecting the power supply.
2-Press the TAP footswitch and LED button above it simultaneously, while turning the pedal on. The LEDs should flash indicating you are in System Mode
3-Open up EDM and go to the left where it says “Check For Updates”. Choose the first one, and reinstall it. The pedal should boot up like normal.
See if you can use EDM like you’re wanting to. Let me know if the problem is fixed.
