Home Forums Products Stompboxes MicroPitch stomp box not working Reply To: MicroPitch stomp box not working
#158035
joecozzi
    You may benefit from a fresh firmware install. Try this:
    1) Download and install the Eventide Device Manager (EDM) for your computer: https://www.eventideaudio.com/support/product/13388/installers
    2) Turn off the pedal and connect the USB cable to your computer.
    3) Then, press & hold the TAP footswitch and LED button above it while turning the pedal on again. You’ll see the LEDs blinking indicating you’re in System Mode.
    4) Open up EDM and click OK once it detects your pedal. Navigate to the left side of the window and click on “Check for updates.”
    5) Select the first option and click “Install Update”
    After installation, the pedal should boot up normally. You should be good to go. Let us know how it works out.
