Home › Forums › Products › Plug-Ins › UltraChannel AU Plugin not working in Garageband › Reply To: UltraChannel AU Plugin not working in Garageband
July 7, 2021 at 9:22 am
#158197
This is very common problem with AUs If you are using a demo version. And, If you’re using pro then you should reinstall audio unit plugin. There are too many issues with AUs on Gargaband so make sure you’re considering the compatibility.
