Home › Forums › Products › Stompboxes › Timefactor Wet/Dry to Normal › Reply To: Timefactor Wet/Dry to Normal
July 9, 2021 at 6:44 pm
#158207
joecozzi wrote:
darietts wrote:
i can’t find the “Routing” menu and i don’t know how to do it. Someone can help me??
In system mode, find the UTILITY category and ROUTING should be the first option. As a reminder, the System Mode Navigation menus/parameters are as follows: 1) Push the Encoder to step down into the menu tree. 2) Turn the Encoder to scroll thru menu items or parameter selections or values. 3) Press the Middle Footswitch to step up the menu tree to upper level menu options.
There’s no Routing in my system mode, i’ve already search for it.
Can be related to the sw version?
