Home Forums Products Stompboxes Timefactor Wet/Dry to Normal Reply To: Timefactor Wet/Dry to Normal
#158208
joecozzi
    darietts wrote:
    Can be related to the sw version?
    Very likely. If you navigated to the UTILITY portion of the system menu tree and you’re not finding ROUTING then you may have an older version of the firmware. I would connect your pedal to computer via USB and use H9 Control to update the software.
