Home Forums Products Stompboxes H9 Max Help! Reply To: H9 Max Help!
#158252
joecozzi wrote:
What is the problem? Are you hearing a clipped signal? Are you having a problem with a particular algorithm?
Yes, audio coming in is too low… and audio going out to my lunchbox amp is clipping – I have to set input gain on the amp to minimum.
Same issue across all algorithms.
