Home Forums Products Stompboxes Eventide space tempo issue Reply To: Eventide space tempo issue
#158256
jorri
    Thanks.
    I’ve tested without the tap switch, and i isolated the power so should be neither.
    No MIDI in setup.
    The speed knob (i think that’s Yknob) displayed no numbers on this preset when turned and had a limited slow range (sometimes it displayed 1/16 only but the tempo is OFF!). Something must have been corrupted in preset memory as it appears fine on the other presets they all show number.
    AFAIK latest firmware.
    What i did is copy the preset to a new location then copy it back. Now the numbers appear to change when turning for now as they should. At least for now and the 3 presets i’ve been focused on recently for this gig- hope there aren’t other corruptions…
