Home Forums Products Stompboxes iPad is not recognizing multiple H9s Reply To: iPad is not recognizing multiple H9s
#158290
daviddb wrote:
Just to reinforce this, I’ve only ever ONCE managed to get 2 H9’s connected simultanously on Bluetooth, and I’ve tried using iPad and Mac Pro.  I’ve ended up doing my preset programming with one H9 connected via iPad and the other one via my Mac.
Daviddb try this:
I want to confirm the above with a slight variation on the above mention workaround,in which in my case i dont press IGNORE
at the first pop up,
1.forget this network on all other bluetooth connected devices
2.Power up the 2 H9s
3.Have them both on a not connected status
4.press connect to the 1st device watching the 2nd blue Led on the pedal.
5.When the second blue Led lights up and the status on ipad shows connected,
6.press quickly connect to the second device,before the 1st pop up window
7.When the 1st pop up appear do nothing it will disapear and soon after a 2nd pop up window appears for approval.
8.Press Allow and watch that the second blue Led on the second device is light up and the Ipad tab sows connected.
9.You now have both units connected .Voila!
IOS 12.8
Ipad Air1
2xH9
