Home Forums Products Stompboxes Is Rose always listening? Reply To: Is Rose always listening?
#158309
joecozzi
    moremusic wrote:
    What is the reverse button actually doing? Its not reversing the hole “loop”, right?
    If you’re referring to the PHI button, it depends on the delay time. Above 20ms it reverses the delay line. Below 20ms it inverts the phase of the delay line
    moremusic wrote:
    Is there a button to clear the buffer? I wish I could clear the buffer when working with long delays (Sound on Sound) without having to change the settings…
    No, there isn’t. I usually set the FEEDBACK to zero and reset it after it clears the delay. You can assign an expression pedal for this type of control, or using MIDI assign a button to toggle between two values.
