Reply To: Micro Pitch Device Mgr. Issue
Home Forums Products Stompboxes Micro Pitch Device Mgr. Issue Reply To: Micro Pitch Device Mgr. Issue
#158364
joecozzi
dirtybuck wrote:
how do I put the info back in the pedal / DM after a reset
To put the info back in the pedal, click “Restore from File” in EDM and select the .bak file you created when you made your backup. If all you changed before was the MIDI channel, there’s no reason why it would mess with any other settings or commands you’re sending from the MIDI controller.
dirtybuck wrote:
2nd, are they working on an update to resolve these issues?
The issue with the MIDI channel and EDM was fixed more than a week ago. Make sure you’re running EDM version 1.9, the latest one on the website.
