Home Forums Products Rackmount Upgrading H9000R firmware from 1.4 (beta tester 2.0) Reply To: Upgrading H9000R firmware from 1.4 (beta tester 2.0)
#158371
    Yes, you'll be able to connect to Emote 1.3 with your H9000 on FW version 1.4
    Keep in mind that you will need an internet connection directly to the H9000 via ethernet or Wi-Fi to see the updates when using Emote 1.3, so depending on how your H9000 is connected to your computer, the USB method may be a better solution.
