Home Forums Products Stompboxes Mixing Link Clarification Reply To: Mixing Link Clarification
#158390
joecozzi
    Yes, the signal gets routed to the effects loop as well.
    By the way, you may connect a microphone and instrument to MixingLink simultaneously. Just be aware that when you insert a plug into the INST IN jack the input to the MIC pre-amp is mixed with the MIC/LINE input and the GAIN control act on both INST and MIC/LINE inputs simultaneously.
