Home › Forums › Products › Stompboxes › H9 midi clock › Reply To: H9 midi clock
August 11, 2021 at 5:40 pm
#158396
DAW clocks are notorious for MIDI jitter. You might want to try setting the H9’s MIDI CLOCK FILTER to ON. Also (counterintuitively), try setting your ASIO buffer size in Ableton to the smallest number of samples that your computer can handle comfortably.
