Home › Forums › Products › Stompboxes › H9 midi clock › Reply To: H9 midi clock
August 12, 2021 at 2:33 am
#158397
captnjones wrote:
Any help is appreciated because this makes the unit semi-usable for me…
thanks
This is not an issue with the H9, its coming from an unreliable (master) clock source. The H9 is telling you that your source is jittering. Today I actually bumped into a dedicated midi clock called Midiclock+ that says 500 nanoseconds of jitter maximum. Check upstream of your H9 and address that to fix the issue…
