Home › Forums › Products › Stompboxes › Mission Engineering SP-H9 expression pedal AUX switch not working › Reply To: Mission Engineering SP-H9 expression pedal AUX switch not working
#158658
    It would appear that the voltage thresholds may have changed in 5.9.0.
    We'll look into it, and, if this proves to be the case, will produce a minor update to fix it.
    This problem probably only applies to the Mission pedal, so users of other switches need not worry.
