Reply To: Swap hotswitch function?
Home Forums Products Stompboxes Swap hotswitch function? Reply To: Swap hotswitch function?
#158695
jorri
joecozzi wrote:
Yes, but it’s not a one-button edit. You simply have to create a preset with the settings inverted. In other words, put the preset in Hotswitch mode and copy the settings. Do the same for the default state. Then, create a preset with your Hotswitch settings as the default, and your old default as the Hotswitch ON settings.
Thanks. That should do I guess, as id only need to copy and change the hotswitched knobs. Or do you mean actually save to another slot whilst hotswitched? as i tried saving the hotswitched preset to the SAME slot and that definitely didnt work.
