Home Forums Products Stompboxes Pre/Post Routing Noise Issue Reply To: Pre/Post Routing Noise Issue
#158714
    Because of the nature of pre/post, it is very prone to ground loops and feedback (which can present as increased noise level).
    Since every setup is different, we can't give much advice, except keep cables as short as possible, and make sure you have a single common main ground connection.
