Home Forums Products Stompboxes Serial Number missing Reply To: Serial Number missing
#158715
joecozzi
    rivkamord wrote:
    Is it possible that it has been upgraded to a MAX but still says CORE on power up?
    No. Even if it’s a converted Max, it should say H9 Max
    rivkamord wrote:
    Also, the serial number on the unit has been removed. Is that a problem or can I still register the pedal?
    You can check the serial number by going into the System Settings > Utility > Ser*. You can also try to pair with it via Bluetooth. The settings will show you the serial number of the pedal.
    rivkamord wrote:
    Just to make things more complicated the pedal is at the moment in a different country than I am so I have to figure these things out remotely
    If you find the serial number, email me at jcozzi@eventide.com and I can tell you what kind of H9 it is in our system.
