Serial Number missing
Home › Forums › Products › Stompboxes › Serial Number missing
    • #116665
      rivkamord
        I just bought an H9 that was supposed to be a MAX but when I power it up it says CORE. Is it possible that it has been upgraded to a MAX but still says CORE on power up?
        Also, the serial number on the unit has been removed (not clear if this was on purpose or by mistake, it was under some velcro attached to the bottom of the pedal. Is that a problem or can I still register the pedal?
        Just to make things more complicated the pedal is at the moment in a different country than I am so I have to figure these things out remotely
      • #158715
        joecozzi
          No. Even if it’s a converted Max, it should say H9 Max
          rivkamord wrote:
          Also, the serial number on the unit has been removed. Is that a problem or can I still register the pedal?
          You can check the serial number by going into the System Settings > Utility > Ser*. You can also try to pair with it via Bluetooth. The settings will show you the serial number of the pedal.
          If you find the serial number, email me at jcozzi@eventide.com and I can tell you what kind of H9 it is in our system.
