Home › Forums › Products › Stompboxes › Cannot Update SW on my H9 Max › Reply To: Cannot Update SW on my H9 Max
#158750
kaiapollo
    I have tried more than one computer get the same issue with both. Also have tried more than one cable. Sadly, it is looking like it may be the unit itself. I have been using the same power supply for 4 years with this pedal, I have 2 H9’s and using  the GigRig power system using a filtered adapter designed for use with Eventide pedals. Neither of my units will connect to the computer at this time, but they were able to 2 months ago. They both connect to my Iphone via bluetooth and the other unit completed the sw update without issue
    joecozzi wrote:
    If the app does not automatically find the connected devices, you will need to do some trouble shooting to determine whether the problem lies with your H9, with your Windows PC, or with the cable connecting the two. One sure fire method to narrow down the source of the problem is to try connecting to your H9 with a different cable on the same computer, and if that does not solve the problem, to try connecting it from a different computer, if possible. If the same connectivity issues does not occur on multiple computers, that would suggest that the problem lies with your computer. If your H9 does not appear as a device or has the incorrect device type, try connecting the H9 to a different USB port on your Windows PC, and if you are connecting through a USB hub, try connecting directly to a USB port on your Windows PC. If your Eventide device does appear in the Device Manager with the correct type, please try closing any digital audio workstation that you may have running on your computer and try disconnecting any other connected Audio MIDI devices from your computer as in rare cases other connected devices can cause driver level communication issues. Also, sometimes just restarting your computer can help. If the same connectivity issues occur on multiple computers, that would suggest that the problem lies with the pedal. In this case please make sure that you are powering your pedal with the power supply that came with your device as under powering a device with a non-Eventide power supply can cause connectivity issues. If the problem persists, please contact support@eventide.com for further help with the issue.
