Home Forums Products Stompboxes Cannot Update SW on my H9 Max Reply To: Cannot Update SW on my H9 Max
#158756
kaiapollo
    Since it failed to load sw now it will not connect even in UPDATE mode
    bohan wrote:
    kaiapollo wrote:
    Well I thought that I was going to get lucky with this. In UPDATE Mode it did connect to the Direct Update, but then this happened:
    And in normal mode H9 Control still doesn’t recognize your H9 via USB? There is another updater software you can try before sending the unit in. Please email support@eventide.com
