Home Forums Products Stompboxes Midi control of Blackhole Pedal via Ableton Reply To: Midi control of Blackhole Pedal via Ableton
#159298
joecozzi
    Make sure that when you choose the pedal on the MIDI track that the MIDI port inputs and outputs are set to “ON.” Otherwise, Ableton won’t be able to communicate with the pedal. The Quick Reference Guide has all of the available controller change numbers that correspond to all the possible parameters of control, so as you automate in Ableton, make sure you’re sending messages using the correct CC#.
