Home Forums Products Stompboxes H9 presets: tuner as default? Reply To: H9 presets: tuner as default?
#159301
joecozzi
    I previously made some presets that (unintentionally) defaulted to tuner when switching with a midi pedal. I’m not sure what I did, but I’d like to do the same with a couple other presets (function: kill switch for entire signal chain when playing live; alternate solution would be do make a preset with zero levels, I suppose). I’m having trouble figuring out how to set this with the H9 control app (new version). Any hints appreciated. Thanks!
    If I understand correctly, you’re looking to put the H9 in tuner mode while at the same time muting the audio, right?
