Home › Forums › Products › Stompboxes › Changing H9 Output options › Reply To: Changing H9 Output options
#160422
markboorman
    Thanks Joecozzi
    so Effectively I need to decide to stay either wet dry And use the H9 mono on the wet side or go stereo. One option may be to go stereo when H9 is in use. For presets on the boss, I may be able to go wet dry using the boss parallel processing only when the h9 is not in use. So my wet side would be from another modulation pedal into the wet Output amp and then dry into a second amp. I can see fun fun testing coming up!
