Home › Forums › Products › Plug-Ins › Split EQ Thoughts & Questions About Precision Drag and Undo › Reply To: Split EQ Thoughts & Questions About Precision Drag and Undo
November 16, 2021 at 11:40 am
#160619
Thanks for the replies and workarounds.
I’m using the plugin, in Reason.
I found something else, trying your suggestions, that you may want to look at, in your investigation. My MacBookPro’s Command key to the left of the spacebar is not recognized to initiate Precision but the one to the right is. I always use the left and never the right, so I didn’t notice at first.
