Home › Forums › Products › Plug-Ins › Split EQ: Reporting UI Issue › Reply To: Split EQ: Reporting UI Issue
November 22, 2021 at 1:00 pm
#160764
Sorry to hear about the issues.
Re: Black screen
- Does this occur if the other instance has the UI open, closed, or in both cases?
- Does this occur if you have “Use OpenGL” on, off, or in both cases? (You can toggle this in the Info dropdown in the top right of the plugin window)
Re: Latency
- What sample rate and buffer size are you using?
- What is the amount of latency that the plugin is reporting, vs. what you are observing?
