Home Forums Products Plug-Ins Split EQ: Reporting UI Issue Reply To: Split EQ: Reporting UI Issue
#160794
Jurgis
    This specific one is from loading a new instance of SplitEQ. It happens intermittently, sometimes it loads up fine, sometimes like this.
    And you know, I’ve noticed something when looking through this support data. It takes note of the language settings used on the mac, specifically
    “UserRegion”: “LT”,
    “DisplayLanguage”: “en-LT”
    I often need to flick between two different language settings while using the computer, and I wonder whether this might be affecting the plugin? That the keyboard and input state being different from the standard ISO/IEC 9995 might be causing some oddities? I will do a few tests and report back.
