Home › Forums › Products › Stompboxes › Rose Pedal, High pitched noise › Reply To: Rose Pedal, High pitched noise
December 3, 2021 at 9:40 pm
#161143
Having the USB cable connected to the pedal is causing a ground loop in your system. The only way to prevent this from happening is somehow isolating the pedal from computer, which is not an easy thing to do. You can try to use a USB isolator though I have not tried one myself. It’s best to just only connect the pedal when you need to use EDM.
