Home › Forums › Products › Plug-Ins › How do i get Generate to work? › Reply To: How do i get Generate to work?
#161153
    Please try the troubleshooting steps below. If you are still having issues email support@eventide.com and reference this post along with what OS you are running and what version of Logic you are using.
    Confirm you have the latest version of your plug-in installed: https://www.eventideaudio.com/products/plugins
    Confirm that you have the latest version of iLok License Manager installed (www.ilok.com).
    Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
    Close your DAW, and delete the following files:AAX: Mac HD/Library/Application Support/Avid/Audio/Plug-ins/New Fangled Audio/<plugin name>.aaxplugin
    VST: Mac HD/Library/Audio/Plug-ins/VST/New Fangled Audio/<plugin name>.vst
    AU: Mac HD/Library/Audio/Plug-ins/Components/<plugin name>.component
    Presets and Docs: ~/Music/New Fangled Audio/<Plugin Name>/ (whole folder)
    Open your DAW and rescan your plug-ins, and then shut your DAW again.
    Deactivate and reactivate the plug-in license in iLok License Manager.
    Reinstall your plug-in
    Reopen your DAW and rescan your plug-ins.
    AudioUnit only: If still not showing, some macOSes occasionally require a restart for Audio plugins to correctly scan.
    Logic:
    Plug-in not showing up after above steps:
    Launch Logic Pro X
    Go to Preferences->Plug-in Manager and select “Reset and Rescan Selection”
    If the plugin fails validation, then copy the output of the white window, and send it to us
    If the plugin passes validation but still does not show in the Insert menus, try the following steps:Close Logic Pro X
    Make sure Finder is the active application
    While holding the Option key, click on the Go menu at the top of your screen and select Library
    Delete the following files from your User Library, if they are present:
    ~/Library/Caches/com.apple.audiounits.cache
    ~/Library/Caches/AudioUnitCache/
    ~/Library/Preferences/com.apple.audio.InfoHelper.plist
    ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
    Then, open a Terminal window (Applications -> Utilities -> Terminal), and enter the following commands (type each command and press “Enter” afterwards)killall -9 cfprefsd
    killall -9 AudioComponentRegistrar
    Restart your computer
    Restart Logic Pro X
    Plug-in not passing validation:
    Launch Logic Pro X
    Go to Preferences->Plug-in Manager, and check if the plug-in is listed
    Highlight the plug-in and select “Reset and Rescan Selection”
    If validation fails, copy the output of the white window, and send it to us
