Home › Forums › Products › Plug-Ins › Split EQ Latency › Reply To: Split EQ Latency
#161236
toco_bt
    Hello.
    My case is a little different. After all, this plugin has a higher CPU cost than other mixing plugins. It takes up 10 percent of the CPU just to load it. I’m hesitant to load this plugin because I have more than 50 tracks in one project. Of course, the performance of the plug-in itself is amazing, but I hope it will be improved in the new version. If this is not possible, please add an optional switch to make it run lighter. Otherwise I will have to explain to my friends that this plugin is for mastering.
    If I may add, I would like to be able to check the version I’m currently using.
