Home Forums Products Rackmount Parametric EQ + low pass and high pass filters algo all in one? Reply To: Parametric EQ + low pass and high pass filters algo all in one?
#161337
    I’ve been looking into some EQ algorithms that you may like as a substitute for 1416 Four Filters, please see below:
    Low Cut / High Cut Algorithms:
    1240 DP_St.EQ45
    1140 St.Compr > EQ45 (same alg as above + compressor)
    1241 DP_St.EQ65
    1141 St  Compr > EQ65 (same alg as above + compressor)
    7851 Sfx Filter/Compress (needs some tweaking from default preset but can work well as a simple low cut / high cut / compressor)
    Low Pass / High Pass Algorithms:
    1218 Stage Parametric (dual 4 band EQ, selectable band pass / low pass / high pass for bands 1 and 4)
    3222 Compr>3Band 8ch (this is 8 mono instances of compressor + EQ)
