Home › Forums › Products › Rackmount › EMOTE / Error Message Sample rate annoying › Reply To: EMOTE / Error Message Sample rate annoying
December 23, 2021 at 6:17 pm
#161365
Yes, that is the obvious solution. Now my setup it is a bit more complicated in reality than explained. Letting the 9k do the job would have been the easiest solution and I thought I could get away using the 9k as a soundcard and be done. Anyway, it means that I will need to find a solution for my problem by reviewing the existing setup.
Cheers
John
