Home Forums Products Stompboxes Using H9 as a volume pedal? Reply To: Using H9 as a volume pedal?
#161411
Bodde
    Thanks for the suggestions apalazollo. The Ultratap is quite cool. But I am just looking for simple delay volume swells with the EXP pedal so the input swell is perfect for that. Except that there is this leaking sound which is fairly annoying because you want it dead quiet in heel position. It does that on all delay algos.
    “What exactly are the improvements in the latest software? Thanks” Mainly faster response to EXP and AUX. This reduces the delay which causes the “zippering.”
    Thanks Nick. I am bit confused though. Does the faster response and less zippering with EXP and AUX only apply when you have H9 control connected or is there also improvement when H9 is not connected (compared fw 3.7.4. with fx4)?
