Home Forums Products Stompboxes Mild, intermitten shock from strings when using H9 Reply To: Mild, intermitten shock from strings when using H9
#161426
cookiemonsk8ter
    Thanks Nick! I’m guessing the one on the Eventide shop is the way to go https://store.eventideaudio.com/collections/accessories/products/replacement-pedal-power-supply
    Would you possibly be willing to clarify the part about the ac center ground pin? Would that be the tip of the ac adapter I am using?
