Home › Forums › Products › Stompboxes › Mild, intermitten shock from strings when using H9 › Reply To: Mild, intermitten shock from strings when using H9
#161428
    “could you possibly be willing to clarify the part about the ac center ground pin”
    By that I means the ground pin on the wall socket you are using. If your electrics are old, you might want to try to multiple ground pins to be sure they are all connected. Be sure to get the right pin …
