Home Forums Products Stompboxes H9 slow patch change with some algorithms Reply To: H9 slow patch change with some algorithms
#161437
joecozzi
    Hello, this is normal behavior. Switching is the fastest when changing between presets that use the same algorithm. When switching between presets from different algorithms, load time is usually dependent on the complexity of the algorithm. Algorithms like PitchFuzz and Harmadillo, for example, are among the most powerful but take more time to load than say algorithms like “Hall” or “Spring.”
