Home Forums Products Stompboxes Using H9 as a volume pedal? Reply To: Using H9 as a volume pedal?
#161473
Bodde
    Can anybody please check it with their expression pedal please? I want to know if it is a bug with the input/output volume thing or if the fault is on my side. I have tested with two expression pedals, only H9 and guitar, no other pedals in between. With or without H9 attached doesn’t make a difference.
    I have tested this and found that there is some signal still preset even when the H9 displays a value of zero on the display for the expression range. I have made our team aware. Thank you for your patience, as our team returns to post-holiday operation.
    Thanks! I am glad it isn’t my mistake. I found out that even without the expression pedal and using the hotknob as an expression device that it still is leaking. Although it is leaking a bit less with the hotknob, but it is still there. I think from memory that it is also leaking a bit when using the expression pedal for output volume, but I am not sure. Hoping  for a solution. Thanks for having a look!
