Home › Forums › Products › Stompboxes › Expression pedal calibration › Reply To: Expression pedal calibration
January 13, 2022 at 3:55 am
#161561
Bodde
I have another question on the same topic: if you use the same expression pedal do you need to calibrate it each time you power up your H9 or does it stay calibrated?
Seems to me that you have to rock the pedal back and forth once before you use it each time that you power up the H9. Is that correct? Or do I have to change a setting so that it starts working immediately?
