Home Forums Products Stompboxes Expression pedal calibration Reply To: Expression pedal calibration
#161587
joecozzi
    That’s fine. Once you go through the calibration process you don’t have to mess with your setup.
    . What do you mean by connecting to your expression pedal first?.
    The H9 measures the load at the expression input when a cable is connected. If there is no expression pedal connected to the other end, we’ll now that’s a problem.
